actually I use a compiled VEE measurement program which runs simultaenously
on three different computers. When starting, the program reads an
initialization file with names of actual hardware, which is different on
each place. The program uses generalized calls to functions e.g. set supply
voltage. This functions uses the information from the initialization file to
switch to the right command and sends this command to the right hardware
device.
The VXE-File comes from one single place on a network drive, however the
initialization file is on a specific drive on each computer.
Hope this helps,
Dr.-Ing. Martin Alles
ATMEL Germany GmbH
SiGe Frontends COM214
POB 3535
Theresienstr. 2
D-74025 Heilbronn, Germany
Tel.: 07131 / 67 - 3152, FAX - 2244,
mailto:martin.alles@hno.atmel.com
http://www.atmel.com
> -----Ursprngliche Nachricht-----
> Von: Gangakhedkar, Deependra D. (MED)
> [SMTP:Deependra.Gangakhedkar@med.ge.com]
> Gesendet am: Dienstag, 30. April 2002 21:03
> An: 'vrf@lvld.agilent.com'
> Betreff: vrf Using single VEE version to run on diff. H/W
> Folks -
> Here's what I would like to do -
> I have a VEE package running on 1 machine using say an HP-XYZ analyser. I
> would like to run the same software on another machine which uses an
> HP-ABC analyser(different analyser).
> Could anyone help me achieve this without having to change the code
> completely???
> Deependra Gangakhedkar
device.
Hope this helps,
ATMEL Germany GmbH
POB 3535
Theresienstr. 2
> Folks -
> completely???
