Ross Bledsoe <RBLEDSOE@Coinco.com> wrote:
>Something probably very simple but I cannot figure out how the attached
>panel has the XEQ pin as an input. On the Add Terminal menu, data input and
>control input are not active. I received the example from a third party
>provider of a digital input card.
>Thanks in advance
Most likely it was either created by hand with a text editor
(watch the syntax!) or more likely created using an earlier version
of VEE. Back in the "old days" (3.2, maybe 4) one could add XEQ
pins to user objects.
Stan
>Thanks in advance
Stan
>Thanks in advance
Stan
