Vee will write to the working directory. You can change it, if you make an
icon on your desktop. There you have the choice of the working directory
yourself.
Best regards
B. Aufenanger
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 91
Fax. : (089) 613 981 23
Email : mailto:Aufenanger@somatec.de
homepage : http://www.somatec.com/
From: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]On
Behalf Of Richard Kleinhenz
Sent: Friday, November 16, 2001 2:13 PM
To: vrf@lvld.agilent.com
Subject: RE: Where does Vee write to and read from by default? (was: vrf s
tuck good with 621 error)
Is that universally true for all versions of Vee? Specifically, in Vee
6.01, does the last directory used for read or write have no effect at all?
Or is there any program action that may change this behavior?
Rich
Richard Kleinhenz
mailto:scubaman@us.ibm.com
845-892-2617
Kenth.Jensen@n
okia.com To: vrf@lvld.agilent.com
cc: Richard
Kleinhenz/Fishkill/IBM@IBMUS
11/16/2001 Subject: RE: Where does Vee
02:55 AM default? (was: vrf s tuck good
with 621 error)
Hi Richard
VEE reads and writes unless other path specified to the working directory,
and that is the directory from where VEE is started up from.
Regards
Kenth Jensen
yourself.
Best regards
B. Aufenanger
Jagdweg 7a
D-82041 Deisenhofen
Rich
Richard Kleinhenz
845-892-2617
Kenth.Jensen@n
cc: Richard
with 621 error)
Hi Richard
Regards
Kenth Jensen
