> I am exporting data from VEE 6 to Exel. The problem is dat VEE has a
> different (strange) way of handling reals. (e.g. 0.7 becomes
> 0.699999999996).
> Is there a way to overcome this problem; e.g. so to get exact 0.7 in
> exel without making use of text-strings?
What you are seeing is simply computer math at work- no computer
represents numbers exactly since they are digital devices. In this case
IEEE 64-bit math cannot exactly represent 0.7. VEE by default
represents it as accurately as IEEE std allows- 0.699999999996
as you note.
Excell also cannot represent this as exact 0.7 (without
using strings) .
What you want , however, is just a number format issue.
When you write to Excel set formatting to the precision that you want
or over in Excell set the formatting as you want- then you
will see "0.7" on the screen as you want.
Stan
PS- note that this is true for ALL programs on all computers-
only the details change, such as number precision and default
formatting.
> 0.699999999996).
as you note.
using strings) .
Stan
formatting.
0.699999999996).
Hans van Zwet
____________________________________________________________________________
Ing. J.M. van Zwet TCA (Technological Control and
assessment)
Tel : +31(0)15-8881211 Brassersplein 2
mailto:jvzwet@office.casema.nl Postbus 345, 2600 AH Delft
