Thanks to all you.
I've found that in VEE5.01 your formula WRITE TEXT a REAL64 STD:1 EOL
leads to an error.
Replacing it with WRITE TEXT a REAL STD:1 EOL (without 64) it works.
But Mike add to his message a file named C.DTF
What kind of file is this?
Stan Bischof (Richard S) <rsb@soco.agilent.com> con fecha 16/04/2002
20:35:57
Destinatarios: Claudio Garcia Casado/INFR/TESA@Telefonica
CC:
Asunto: Re[2]: vrf Formatting numbers
claudio.garciacasado@telefonica.es wrote:
> Sorry Stan: I've received your vee program as text. It has been a rapid
> answer.
> I've copied it with the Notepad, and saved as vee.
> When I try to execute it, an error message doesn't allow to see your
> "contribution".
> Try to send as an attached file.
> Gracias. Thanks
It is just a TO STRING with one transaction
if you really want the leading zero then a formula can
add this in as needed
Stan
___________________________________________________________________________
Este mensaje se dirige exclusivamente a su destinatario y puede contener
informacin privilegiada o confidencial. Si no es vd. el destinatario
indicado, queda notificado de que la utilizacin, divulgacin y/o copia sin
autorizacin est prohibida en virtud de la legislacin vigente. Si ha
recibido este mensaje por error, le rogamos que nos lo comunique
inmediatamente por esta misma va y proceda a su destruccin.
This message is intended exclusively for its addressee and may contain
information that is CONFIDENTIAL and protected by professional privilege.
If you are not the intended recipient you are hereby notified that any
dissemination, copy or disclosure of this communication is strictly
prohibited by law. If this message has been received in error, please
immediately notify us via e-mail and delete it.
leads to an error.
20:35:57
CC:
> answer.
> "contribution".
> Gracias. Thanks
Stan
