vrf Watch out for 603!
Question asked by VRFuser on Jun 10, 2002
Latest reply on Jun 10, 2002 by VRFuser
I've confirmed that this is indeed a defect in both 6.03 and 6.1. It does
not show up in 6.01. I'll submit it to our defect data base.
We'll inform the vrf when we have more info on this problem and how we plan
to deal with it.
Further information: the defect also causes the generated Formula or Call
box to be missing at least some (all of them in my test case) of its input
and output pinss. I tried it using the Example in libs called SMTPMail.vee
. In 6.01, the generated Call for ParseAddressString was preloaded with one
input pin and two output pins. In 6.03 and 6.1, the same Call had no input
or output pins.
Obviously I wish we didn't have this defect, but given that it was there,
I'd like to say thank you, Barrie for finding and describing it. Your
description made it easy to know how to reproduce it.
Sincerely,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> -----Original Message-----
> From: Barrie Walden [mailto:bwalden@whoi.edu]
> Sent: Sunday, June 09, 2002 2:03 PM
> To: Agilent Reflector
> Subject: vrf Watch out for 603!
> I hope the 603 patch was a rush job and not indicative of the Version
> 6.1 workmanship.  Merge a User Function into an existing
> application and
> then try to generate a "Call".  Seems to work but that little speck of
> dirt on your monitor in front of the function's name isn't a speck of
> dirt and you are going to get an error when you run your application.
> Now try to add a "Formula Call" - same result only faster.
> Finally, try
> to delete the User Function entirely - hopefully you remember
> "shift-delete" because it's the only way it can be done.   I
> found this
> within 5 minutes of beginning to use 603 - I wonder what I
> could find in
> an hour.   UGH!!!!
> Barrie
> This is the "vrf" maillist, managed by Majordomo.  To send messages to
> this maillist, just email to "vrf@lvld.agilent.com".
> Subscriptions and
