Greetings VEE World,
I have not yet found any information about how to set the screen position of
the VEE main panel on execution of the program. The programs I have written
open up in different positions after they are executed. I would like the
position to be referenced to the upper left corner (0,0). Can someone
please help me with this task. I am using MS Windows 98 with VEE 5.01.
Vincent Petrone
Engineering Technician
Kathrein inc., Scala Division
Medford, Oregon USA
Vincent Petrone
Medford, Oregon USA
out with the alphanumeric box shows a 2 column array of data....i save this
with file I/O as WRITE TEXT a EOL with the default format set....when I
look at the file using Notepad instead of seeing a 2 colum file, I only see
a 1 column file....all the data is there except it's all in 1 column....what
am I doing wrong?
Another issue I have concerns Matlab figure windows and VEE....I have an OK
button in my VEE program which I use to pause the program after a Matlab
figure has come up...the purpose of the pause is to let the user decide
whether he wants to save the file of data or not...however, when I hit the
OK button the Matlab figure minimizes whereas I want it to stay on the
screen...is there any way to avoid this?
thanks.....jerry blimbaum NSWC panama city, fl
