The command line switch -geometry 800x600+0+0 will set the window size to
800 by 600, at position 0,0.
Reiner
Sent: Monday, October 21, 2002 11:08 AM
To: VEE vrf
Subject: [vrf] How do you set the initial screen position of the main
VEE panel on execution
Greetings VEE World,
I have not yet found any information about how to set the screen position of
the VEE main panel on execution of the program. The programs I have written
open up in different positions after they are executed. I would like the
position to be referenced to the upper left corner (0,0). Can someone
please help me with this task. I am using MS Windows 98 with VEE 5.01.
Vincent Petrone
Engineering Technician
Kathrein inc., Scala Division
Medford, Oregon USA
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
Reiner
To: VEE vrf
Vincent Petrone
Medford, Oregon USA
