That sounds likely, Bob......
Does anyone know a way round it, or any other way I can kill a function
from "outside" ??
Paul F.
Wirth_Robert@emc.com To: Paul.Fowler@raytheon.co.uk
15/11/02 cc:
13:28 Subject: RE: [vrf] Strange Formula Call Behaviour
I think its because the UserFunction will not timeslice if the call is
pass to a formula object via the control pin. The Call function will
timeslice.
I use this "feature" to control some of my critical sections of code,
to ensure other threads stop running while i'm doing some timing tests,
etc.
This is buried in the Advanced Vee Techniques manual in chapter 11.
Bob W.
> -----Original Message-----
> From: Paul.Fowler@raytheon.co.uk
[SMTP:Paul.Fowler@raytheon.co.uk]
> Sent: Friday, November 15, 2002 7:45 AM
> To: VEE vrf
> Subject: [vrf] Strange Formula Call Behaviour
> VEE Gurus.........
> Please help me out with the attatched, it's driving me nuts.
> Thanks
> Paul F.
> (See attached file: Abort_Problem.vee) << File: Abort_Problem.vee >> <<
> File: footer >>
> timeslice.
> etc.
> Bob W.
> From: Paul.Fowler@raytheon.co.uk [SMTP:Paul.Fowler@raytheon.co.uk]
> To: VEE vrf
> VEE Gurus.........
> Thanks
> Paul F.
> << File: footer >>
