Thanks Bern Muller,
after some try and error I found an older driver that works (core 6.1.0.4
from data translation OmniCD V 2.0 Rev B).
Regards, Felix Landhuer
Von: Bern Muller [mailto:bernhard.muller@dlcdesignaudio.com]
Gesendet: Freitag, 12. Juli 2002 15:33
An: Landhaeusser Felix (DS/EIM2) *
Betreff: Re: vrf no waveform output with data translation dt3001 under
w2k
We have had the same problem. This is apparently due to a "feature" of the
new W2k drivers. I called tech support, and they sent me an older version of
the driver that seems to work OK. Apparently the new driver wants the number
of samples to be something specific, but the error message doesn't tell you
what.
----- Original Message -----
From: "Landhaeusser Felix (DS/EIM2) *" <Felix.Landhaeusser@de.bosch.com>
To: <vrf@lvld.agilent.com>
Sent: Friday, July 12, 2002 1:43 AM
Subject: vrf no waveform output with data translation dt3001 under w2k
> Hello VEE users,
> since my update to w2k the waveform output with data translation dt3001
> board don't work in VEE4, 5 or 6. I used the recent driver vom datx
website.
> Even the example programm dasimple.vee from vee help menu stops with error
> message, which is cut in 3rd row ...
> VEE RunTime Error
> DT Open Layers error:
> 220, Requested operation requires that valid samples in buffer be a
multiple
> of
> In Compiled Funkttion 'Put Data'
> Object title: PutDataPrimitive
> Object type: Call
> Error number: 2000
> Thanks for any help,
> Felix Landhuer
> Robert Bosch GmbH
> DS/EIM2
> P.O. Box 30 02 20
> D-70442 Stuttgart
> Germany
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
"vrf-request@lvld.agilent.com".
board don't work in VEE4, 5 or 6. I used the recent driver vom datx website.
VEE RunTime Error
220, Requested operation requires that valid samples in buffer be a multiple
of
Object type: Call
Error number: 2000
Felix Landhuer
Robert Bosch GmbH
DS/EIM2
P.O. Box 30 02 20
D-70442 Stuttgart
Germany
