You can put a record constant on your panel view, then add a "Default value"
control input to the record constant. Feed your record into that control
input. It will also accept a record array.
Or you can display the record in an alphanumeric object but it's not very
easy to read.
Warren Pickles
From: Kevin Valentine [mailto:kevin@physchem.ox.ac.uk]
Sent: 28 August 2002 11:42
To: VEE vrf
Subject: [vrf] Record view on a panel
Can anybody tell me if it is possible to add a record view to a panel? What
I would like to do is show the user what the contents of a record looks
like so that they can decide whether it is correct or not. The
Create/Edit/View Record pop-up would be ideal but I cannot find a way to add
this to a panel or to get it to appear during execution. The only way I can
find to do this is to create a custom panel and put each field of the record
into a separate AlphaNumeric display on the panel.
Thanks
Kevin Valentine
You are currently subscribed to vrf as: picklesw@tycoelectronics.com
easy to read.
Warren Pickles
To: VEE vrf
Thanks
Kevin Valentine
Thanks
Kevin Valentine
