vrf Example for E1413A firewire and vxi
Question asked by VRFuser on Jul 15, 2002
Hi Lambert,
had the time to install your driver and saw the fifo fast command with it's
description. You can read in the grey window below, with the fast fifo
function selected, that you have to send this special data format command
before( Form PACK,64). This can be done by using the send_string
function in the PassThrough section. This section allows to send plain
SCPI commands using VXI PnP.
Be aware that you have to scroll manually down ( after clicking the + ) to
the PassThrough section. This is a common VXI PnP driver bug.
Best regards
Christian
BIOTRONIK GmbH & Co.
EWE 51/CW
D 12359 Berlin - Neuklln
Tel.: +49 30 689 05 - 301
christian.wienhold@biotronik.de
