vrf Access data storage. (Local & on Server).
Question asked by VRFuser on Sep 1, 2002
<!doctype html public "-//w3c//dtd html 4.0 transitional//en"><html>Hello Gavin,
We have made for our test executive rtmTE a solution similar what youare asking for. The design is a server-based database in Access (or MS-SQL)and a locally database in Access on each test station. The server-baseddatabase is updated after each device/item/product/ tested. If for somereason the server based database is not connectable the locally databaseis updated. So next time a device/item/product/ is tested we check if thereare any data in the local database and if so the locally stored date ismoved to the server-based database.
The code to handle the database is written i Visual Basic and it iscalled from within the Vee environment<p>Best regards<p>Svante Sundelin<p>Rationell Teknik och Management AB
Nytorpsvägen 24, Box 1723 183 17 Täby, Sweden
<a href="http://www.rtm.se/"> www.rtm.se.</a>
 <p>gavin.candy@bhc.co.uk wrote:<blockquote TYPE=CITE>Hi VRF,<p>     I am currently storing test data to a Accessdatabase on a server.
The problem is that the server, from time to time will be disconnectedfrom
the network.
A option I have been looking at is too store a local copy of the database
on the
machine running Vee Pro & then every so often copy the databaseto the
server.
Obviously I will need to check that the server is active.<p>Has anybody had experience in this area?<p>Any code or help will be appreciated.<p>Thanks for your help in advance.<p>Thanks<p>Gavin Candy.
Quality Engineer.
BHC Components Ltd
20-21 Cumberland Drive
Granby Industrial Estate
Weymouth
DT4 9TE
England<p>Tel:           ++44 1305 830734
Fax:          ++44 1305 760670
Email:        gavin.candy@bhc.co.uk
website:    <a href="http://www.bhc.co.uk">http://www.bhc.co.uk</a><p>---
You are currently subscribed to vrf as: svante.sundelin@rtm.se
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</blockquote>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,  email "vrf@it.lists.it.agilent.com".  <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</html>
