I have an additional query. It was recently brought to my attention by another
VEE user that there once appeared on the VEE reflector a good way to create a
Windows-like drop-down menu using VEE. Apparently this was posted some time
ago (perhaps years) and I don't know if it required Active X to accomplish
this. If anyone knows what this might refer to and can find such an example
please post it. Thanks.
Shaun Trussler
From: ext Goldberg, Mark [mailto:Mark.Goldberg@ATK.COM]
Sent: 07 August, 2003 09:47
To: VEE vrf
Subject: [vrf] Active X Menu Question and Sample.
Hello All VRF-ers:
I have been playing around with the ActiveX toolbar object for a menu and
have attached a sample program. I have used this to replace the older VEE
Menu that was passed around years ago. It works well, but I would like to
get rid of the Arrows next to each dropdown and have the buttons themselves
activate the menu. Does anyone have any suggestions?
Thanks
Mark Goldberg
I had that menu, and have used it in the past. The reason I switched to this
menu is that except for the arrows this one is more like windows than the
ALL VEE version and the ALL VEE version is a resource hog. If you have
anything else running it will slow the system down.
Mark
From: Shaun.Trussler@nokia.com [mailto:Shaun.Trussler@nokia.com]
Sent: Thursday, August 07, 2003 10:05 AM
To: VEE vrf
Subject: [vrf] RE: Active X Menu Question and Sample.
another
a
Shaun Trussler
To: VEE vrf
Hello All VRF-ers:
Thanks
Mark Goldberg
You are currently subscribed to vrf as: Mark.Goldberg@ATK.COM
Mark
To: VEE vrf
another
a
Shaun Trussler
To: VEE vrf
Hello All VRF-ers:
Thanks
Mark Goldberg
