"Baranski, Detlef" <Detlef.Baranski@PILKINGTON.de> wrote:
> Hi List,
> did anybody have an example of the use of a zip or other compression
> technology within vee to crunch measurement- datas automatically ?
Haven't played with it, but if you're in XP you should be able
to use the OS's built-in ZIP capability.
Anyone know definition file for zipfldr.dll ?
With that you just create a zip file and then write whatever data
you want into the file.
Stan
> Hi List,
Stan
Windows has built-in Lempel-Ziv. Search for the LZ family of functions
starting with LZOpenFile at http://msdn.microsoft.com/library. They are also
compatible with the Microsoft extract.exe utility.
Dealing with the OFSTRUCT is definitely a pain though. The easiest thing to
do is pass a command line to pkzip or arj or other archiver with an Execute
Program object. I'm not familiar with any automation libraries that offer
compression, but I'm sure they're out there.
-SHAWN-
