Hi Tim,
it's new for me that VEE only supports 4 COM ports. Have you runned the
IOconfig, after installing the multi IO card? You must see the COM ports on your
system before using them with VEE
Ralf
Ralf
one com port box and added a device name (if memory serves correctly) input
pin and cycled through the port names using a for range box and a formula
box to drive the serial port object.
I don't think VEE has any limit on the number of ports.
Mark
Sent: Wednesday, July 17, 2002 7:05 AM
To: vrf
Subject: vrf talk to 10 serial ports
Does anyone know how to connect more than 4 serial ports in VEE. I have 10
ports (com1 to com10) but VEE only supports 4. Thank you.
Tim Xing
Dept. of Engineering
Labconco
8811 Prospect Ave.
Kansas City, MO. 64132
(816) 822-3759
