Karen -
> I can't say it was
> much fun to figure
> out.
Awwww... The 8255 *was* fun!
> Do you know if VEE has a
> preferred card that is quick
> and easy to program with?
Well I don't know about preferred but last time I used Keithley it was
pretty cool. They don't explicitly support VEE but they have some really
excellent support ware. The card is pretty nice too. Depending on what
adddress range you use, you can use it in 8255 emulation mode or just about
any combination of bit-wise modes that you care to find useful. My favorite
is an array of single bits. Everything is nice and uncomplicated that way.
Unfortunately the ActiveX control doesn't allow access to these other modes
(it only talks to the card at it's base address). Also, if you're using a
protected OS (like NT or UNIX) then you're pretty much stuck with 8255 emu
mode too (unless you care to write your own driver).
-SHAWN-
"Geek used to be a four letter word. Now it's a six figure one."
> I can't say it was
> much fun to figure
> out.
-SHAWN-
Greetings All,
I need to buy a pio24 card to use with VEE 6.0. I've used VEE with a
National Instruments PIO24 before, but I can't say it was much fun to figure
out. Do you know if VEE has a preferred card that is quick and easy to
program with? Someone will be writing a C routine that uses the card, and I
will be calling the routine in VEE.
Thanks a lot,
Karen
Karen Bourque Werner
Research Assistant - FCRAO
Department of Astronomy
726 Lederle Graduate Research Center
University of Massachusetts
Amherst, MA 01003
phone: 413.545.9603
phax: 413.545.4223
