Doesnt anyone ever use the Rich Text Box Active X
Control on a Vee UF? There is a shipped example
using it, and you can sure pretty up text with it, and
it is a standard control for Windows so it will be on
almost all systems. To make it useful, you would have
to go beyond the example and probably start with an
rtf template and do string search and substitutions,
which admittedly isnt trivial but not that hard. Just
wondering.
Greg
--- Kathy Kiessling <kathy.kiessling@endwave.com>
wrote:
> Often times, vrf does NOT put 'vrf' in the title,
> making it harder for
> outlook to sort out this mail. Interestingly, this
> mostly happens with Mike
> Groves' postings.
> Kathy Kiessling
> Endwave Test Engineering
> (530) 295-4055 ph <-- new
> -----Original Message-----
> From: Mike Groves [mailto:Mike_Groves@cree.com]
> Sent: Friday, July 26, 2002 1:35 PM
> To: VEE Reflector (E-mail)
> Subject: Terrible tabs revisited
> << File: Tab2.vee >> Hello VRFers, Happy Friday!
> About 6 months ago I reported a bug that involved
> using a TAB character
> ( ) to align data on a Logging AlphaNumeric
> display. It was useless as
> the TAB would align itself to the underlying grid
> instead of the Logging
> Alphanumeric box. Meaning, if you moved the box
> slightly, the tabs would
> shift their positions pushing your data around.
> Well today I found another instance of this same
> problem, this time with
> the output pin of a formula box and also the wire
> connecting it to the
> input of a regular AlphaNumeric display.
> See the attachment for details.
> I would be curious if anyone running VEE 6.1 (or the
> demo) could report
> if this occurs there also.
> Thanks,
> Mike Groves
> Cree Microwave
> This is the "vrf" maillist, managed by Majordomo.
> To send messages to
> this maillist, just email to "vrf@lvld.agilent.com".
> Subscriptions and
> If you need details, just send a message containing
> the text "help"
__________________________________________________
Do You Yahoo!?
Yahoo! Health - Feel better, live better
http://health.yahoo.com
wondering.
Greg
> Groves' postings.
> Kathy Kiessling
> demo) could report
> Thanks,
> Mike Groves
> Cree Microwave
> To send messages to
> Subscriptions and
> the text "help"
Do You Yahoo!?
outlook to sort out this mail. Interestingly, this mostly happens with Mike
Groves' postings.
Kathy Kiessling
About 6 months ago I reported a bug that involved using a TAB character
( ) to align data on a Logging AlphaNumeric display. It was useless as
the TAB would align itself to the underlying grid instead of the Logging
Alphanumeric box. Meaning, if you moved the box slightly, the tabs would
Well today I found another instance of this same problem, this time with
the output pin of a formula box and also the wire connecting it to the
I would be curious if anyone running VEE 6.1 (or the demo) could report
Mike Groves
Cree Microwave
