vrf Using the ToolHelp library
Question asked by VRFuser on Sep 2, 2002
OOPS! The "Path" item under "Modules" under each process duplicates the name
of each loaded module. Yeah - it's not perfect
If you wanna fix this bug, open the function ShowModules. In the formula box
titled, "Add Module Data," the first line is at fault:
tv.Nodes.Add(szModuleKey, tvwChild, szModuleKey + "_EP",
"Path.............. : " + pme[idx].szExePath + pme[idx].szModule);
It should be:
"Path.............. : " + pme[idx].szExePath);
-SHAWN-
