Ren Srensen <rs@rmteknik.dk> wrote:
> This is already done but I need the data in memory to be able to display and
> work on.
> The problem is that the Concanator eats up memory.
Try using the collector instead of the concatenator. perhaps it doesn't
have the same problem.
Stan
> work on.
Stan
work on.
-----Oprindelig meddelelse-----
Fra: Christian Wienhold [mailto:christian.wienhold@biotronik.de]
Sendt: 20. november 2002 07:52
Til: Ren Srensen
Emne: Re: [vrf] Memory leak ??
Save your data sequential to file without checked 'Clear File at Prerun and
Open'. After last write cycle send Execute Close. This keeps used memory
at a minimum and saves your data in case of a system crash up to that
time.
Hope it helps
Christian
BIOTRONIK GmbH & Co.
EWE 51/CW
D 12359 Berlin - Neuklln
Tel.: +49 30 689 05 - 301
