> add of a dummy *junction* before
> pinging the *next* object
Pierre, that is amazing! I'm happily wrong and thanks for the tip.
-SHAWN-
-SHAWN-
Unless I am missing something the original Vee program with the message box
next, continue and break works correctly. The next meaning is to continue within the loop
of the Until Break, the continue pin hangs and is not handled which means continue
within the loop of the Until Break and the break goes the bottom sequence
pin of the Until Break box and then stops. In a loop or outside a loop you need to handle
all the sequence pins or the understanding of your program may present problems.
Harry Walker
