Hi all
How can I start Outlook using ActiveX controls. The example with VEE,
requires that outlook is running first.
An example will be appreciated.
Thanks to you all in advance
Chris Phipps
Chris Phipps
Hello;
Would anyone have an example of using the "To/From Socket" ?
I'm trying to use the "To/From Socket" for Direct IO thru a dedicated lan port.
Any example/info would be most helpful.
Thank You
Chris Gove
Agilent Technologies.
