<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META http-equiv=Content-Type content="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2600.0" name=GENERATOR></HEAD><BODY><DIV><SPAN class=331552413-30102002><FONT face=Arial size=2>I want to check whether an instrument requests service. I first use Interface Event SRQ and then the Instrument Event Spoll.</FONT></SPAN></DIV><DIV><SPAN class=331552413-30102002><FONT face=Arial size=2>The problem is, that the instrument (GPIB address) shall be set via a command file during runtime, and the Interface event does not provide a control input to select a specific instrument address. </FONT></SPAN></DIV><DIV><SPAN class=331552413-30102002><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=331552413-30102002><FONT face=Arial size=2>Is there a fast and easy way around this problem?</FONT></SPAN></DIV><DIV><SPAN class=331552413-30102002><FONT face=Arial size=2>Why is there no control input to select the device address, as it is with e.g. a Direct I/O?</FONT></SPAN></DIV><DIV><SPAN class=331552413-30102002><FONT face=Arial size=2></FONT></SPAN> </DIV><DIV><SPAN class=331552413-30102002><FONT face=Arial size=2>Kind regards</FONT></SPAN></DIV><DIV><SPAN class=331552413-30102002><FONT face=Arial size=2>Hans-Joachim Fischer</FONT></SPAN></DIV><DIV><P class=MsoNormal><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">----------------------------------------------------------------------------------<BR>Elektrische Signalverarbeitung Dr. Fischer GmbH<BR>Dr. Hans-Joachim Fischer</SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR></SPAN><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">Geschftsfhrer</SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR></SPAN><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">Brennerweg 7</SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR></SPAN><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">89143 Blaubeuren</SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR></SPAN><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">+49-7344-91969-3</SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR></SPAN><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">+49-7344-91969-1 (Fax)<BR>+49-175-40 74 5 74 (mobil)</SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR></SPAN><A href="http://www.fischer-tech.de/"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">http://www.fischer-tech.de</SPAN></A><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR></SPAN><A href="http://www.esf-gmbh.de/"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">http://www.esf-gmbh.de</SPAN></A><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR></SPAN><A href="http://www.rttt-dsrc.de/"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; mso-ansi-language: EN-GB">http://www.rttt-dsrc.de</SPAN></A><SPAN lang=EN-GB style="mso-ansi-language: EN-GB"><BR><FONT size=2>----------------------------------------------------------------------------------<BR>This e-mail, and files transmitted with it, are for the sole use of the recipient(s) and should not be forwarded without permission. Personal messages do not necessarily represent the views of Elektrische Signalverarbeitung Dr. Fischer GmbH.<BR>You may not copy this information or use it or disclose it to anyone else. If you have received this message in error, please notify the sender and delete it from your system immediately. <BR>Elektrische Signalverarbeitung Dr. Fischer does not accept liability for errors, viruses or omissions in the content of this message.<BR>----------------------------------------------------------------------------------<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></FONT></SPAN></P></DIV><DIV> </DIV>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@it.lists.it.agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
