I would like to know how to compile instrument drivers from source code (*.id to *.cid) that I have developed without running the VEE set-up program. Thanx
Stan B
Ekb0503@aol.com
Stan B
Ekb0503@aol.com
asReal64("0x"+A)
or use a FromString transaction to read in hex format.
Bill Ossmann
bill_ossmann@hsgmed.com
Philips Ultrasound
>-----Original Message-----
>From: Shaun.Trussler@nokia.com [mailto:Shaun.Trussler@nokia.com]
>Sent: Thursday, August 15, 2002 1:19 PM
>To: VEE vrf
>Subject: [vrf] Converting text (in hex) to a number in decimal
>Greetings All:
>I have looked for a function that will take text representing
>a hex number (e.g 2F) that can make a conversion to either
>a INT or Real decimal number (in this case 2F to 47). I
>haven't found a built-in function that will do this and perhaps
>none exists. If so, has anyone written a piece of code that
>will do this? I realize it would be possible to crudely map an
>array of text to an array of decimal numbers but I was looking
>for something more elegant. Thanks for any assistance.
>Regards,
>Shaun Trussler
>You are currently subscribed to vrf as: bill_ossmann@hsgmed.com
