Kevyn,
-maximize should work, tho I've never used it. If you look in VEE help
under "command line options" in the index, it lists them all. I always use
-geometry, as my panels are build to a particular screen resolution.
Remember to include the full path to the vee executable, in quotes, followed
by the command line option, followed by the full path of the .vee program,
in quotes.
Reiner
Sent: Wednesday, October 16, 2002 2:39 PM
To: VEE vrf
Subject: [vrf] Windows NT maximize Command
Hello everyone,
I am looking for the command line syntax for maximizing a window in VEE. I
am using windows NT and the -maximize switch does not work. I know that
with NT you must tell it where and how big, but I don't know the syntax for
doing this. Does anyone know how to maximize a window in NT????
Kevyn R. Pair
Channel Master, LLC.
919-989-1645
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
in quotes.
Reiner
To: VEE vrf
Hello everyone,
Kevyn R. Pair
919-989-1645
Kevyn R. Pair
919-989-1645
