Thanks, Edward and Bill. Now that we're back from our enforced 2-week vacation, I have received Bill's defect report and will verify and submit it for R&D to look at.
Thank you for a very complete and understandable report, Bill.
Vrf-ers, when you find a defect, please use the "Report a Software Defect" form found under the "Support" link in ADN Basic and Pro. You can register for ADN at < www.agilent.com/find/adn >. ADN Basic is free.
You can also submit enhancement requests with that form.
Note that we don't normally individually acknowledge submissions made with that form; the workload would be too great. But since this came up on the vrf, and the vrf is special, I decided to acknowledge. I was only able to do it this time because our workload is low right now, but normally, we would not even respond on the vrf.
Hope everyone is having a great New Year.
Sincerely,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> -----Original Message-----
> From: bill.ossmann@philips.com [mailto:bill.ossmann@philips.com]
> Sent: Monday, December 30, 2002 8:47 AM
> To: VEE vrf
> Subject: [vrf] Re: Complex Exponentiation : VEE Formula vs. MATLAB
> Script
> Very curious!
> I see the behavior you describe, and I'll add the following
> observations:
> (0,1)^(a+bi) appears to work properly except for the cases
> when abs(b)==1 and abs(a)<~1.9e-8
> (0,1)^Z appears to work properly if Z is an array containing
> (0,1). This could give you a workaround, since even
> (0,1)^[(0,1)] works correctly.
> We have validated a number of VEE programs against the same
> calculations in MATLAB (not script) and gotten excellent results.
> Regards,
> Bill Ossmann
> Philips Ultrasound
> To: "VEE
> vrf" <vrf@it.lists.it.agilent.com>
> cc:
> (bcc: Bill Ossmann/ANR/MS/PHILIPS)
> Subject:
> [vrf] Complex Exponentiation : VEE Formula vs. MATLAB Script
> "Edward Poncin"
> Classification:
> <ed_poncin@hotmail.com>
> 12/27/2002 11:49 AM
> Please respond to
> "Edward Poncin"
> COMPLEX EXPONENTIATION : VEE FORMULA vs. MATLAB Script
> I reported this error to Agilent some months ago. I was running
> VEE in a WINDOWS environment. There is an interesting but
> somewhat obscure equation, in which the complex operator 'i' is
> raised to the power of itself. In computerese, this is : (i^i ).
> With pencil-and-paper methods it is easily proven to be :
> exp (-PI/2 ) = 0.2079 ( approx ).
> When I use the VEE Formula object to calculate this complex
> exponential, the result is given as ( 0, 1 ) --> meaning 'i',
> which is WRONG.
> When I use the MATLAB script to assess the same quantity,
> the numerical value is given as 0.2079, which is correct to the
> number of decimal places chosen.
> A closely related equation occurs when the natural logarithm of
> each side is taken. Pencil-and-paper methods yield :
> i * ln(i) = ( -PI/2 )
> Oddly enough, the VEE Formula object yields the correct answer
> for this calculation. MATLAB handles it correctly, also.
> Has anyone else encountered large discrepancies between results
> of the VEE Formula and MATLAB script ?
> Ed Poncin
> _________________________________________________________________
> STOP MORE SPAM with the new MSN 8 and get 3 months FREE*.
> http://join.msn.com/?page=features/junk ... &PS=47575&
PI=7324&DI=7474&SU=
http://www.hotmail.msn.com/cgi-bin/getmsg&HL=1216hotmailtaglines_stopmorespam_3mf
You are currently subscribed to vrf as: bill.ossmann@philips.com
You are currently subscribed to vrf as: scott_bayes@agilent.com
Sincerely,
Scott Bayes
970 679 3799 Tel
970 635 6867 Fax
> To: VEE vrf
> Script
> Very curious!
> observations:
> Regards,
> Bill Ossmann
> Philips Ultrasound
> To: "VEE
> cc:
> Subject:
> "Edward Poncin"
> Classification:
> 12/27/2002 11:49 AM
> Please respond to
> "Edward Poncin"
> which is WRONG.
> Ed Poncin
PI=7324&DI=7474&SU=
This is apparently my week for simple questions. I need to break a
string into component pieces and place them in an array - exactly what
"FromString - token" does so well. Unfortunately, my items are comma
separated data values and when one is missing the input string has two
commas in quick succession. In such a case, the Token splitter gives an
array with fewer than normal items and therefore the array index numbers
are affected (i.e. the normally fifth item becomes the fourth). I need
to load the array consistently - the 5th item must always be the 5th
even when the 2nd is missing.
As an example:
Normal string = $GPVTG,181,T,197,M,00.2,N,00.1,K*41
Array = ["$GPVTG" "181" "T" "197" "M" "00.2" "N" "00.1" "K*41"]
and Array[7] = "00.1"
Odd string = $GPVTG,181,T,197,M,,N,00.1,K*2A
and Array[7] = "K*2A"
I need to access the 00.1 value in an equation using a consistent array
index number so I want the array to look like this: ["$GPVTG" "181" "T"
"197" "M" "" "N" "00.1" "K*41"]
I have some complicated code that replaces all commas with a ",~"
combination, then splits the string using Token, and finally strTrim()s
all "~" characters. It works but it sure is complex. Any suggestions?
Barrie
