vrf VEE Error 999
Question asked by freal on Sep 24, 2003
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2800.1141" name=GENERATOR><STYLE></STYLE></HEAD><BODY bgColor=#ffffff><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=250434214-25092003>Kjeld,</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=250434214-25092003></SPAN></FONT> </DIV><DIV><FONT><SPAN class=250434214-25092003><FONT face=Arial color=#0000ff size=2>I believe I had run into this same problem 2-3 years ago with WinNT/2000 and Win95/98. The MS operating system that are not DOS based (WinNT/2000/XP) can handle directory delimiters of "\" whereas the other operating systems only like one slash "". Try changing the default text to </FONT><A href="file://\Rum115_254arc159default"><FONT face=Arial size=2>\Rum115_254arc159default</FONT></A><FONT face=Arial color=#0000ff size=2> </FONT></SPAN></FONT><SPAN class=250434214-25092003><FONT face=Arial color=#0000ff size=2>and see if this helps on the 98se system. Also Rich's suggestion on Windows authentication can also cause problems if the currently logged in user does not have read/write permissions on the server, so testing at a command prompt will indicate if this also is causing a problem.</FONT></SPAN></DIV><DIV><SPAN class=250434214-25092003><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=250434214-25092003><FONT face=Arial color=#0000ff size=2>Thanks,</FONT></SPAN></DIV><DIV> </DIV><BR><BR><P><FONT size=2>Lyle Carnahan<BR>Aerospace and Defense Business Unit<BR>M/A-COM  Inc.<BR>1011 Pawtucket Boulevard<BR>Lowell, MA  01853-3295<BR><BR>Phone: (978) 442-4504<BR>Fax:   (978) 442-4520<BR>carnahal@tycoelectronics.com<BR><BR></FONT></P><BLOCKQUOTE>  <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma   size=2>-----Original Message-----<BR><B>From:</B> Kjeld Alexander   [mailto:k.alexander@get2net.dk]<BR><B>Sent:</B> Thursday, September 25, 2003   3:29 AM<BR><B>To:</B> VEE vrf<BR><B>Subject:</B> [vrf] win98   problem<BR><BR></FONT></DIV>  <DIV><FONT face=Arial size=2>Hi all,</FONT></DIV>  <DIV><FONT face=Arial size=2></FONT> </DIV>  <DIV><FONT face=Arial size=2>I have 2 laptop, one running win98se vee6.01.The   2nd running XP home vee6.01.</FONT></DIV>  <DIV><FONT face=Arial size=2></FONT> </DIV>  <DIV><FONT face=Arial size=2>Running the attached program on xp home create   folder(s) no problem.</FONT></DIV>  <DIV><FONT face=Arial size=2></FONT> </DIV>  <DIV><FONT face=Arial size=2>No folder are createt on the win98se   laptop.</FONT></DIV>  <DIV><FONT face=Arial size=2></FONT> </DIV>  <DIV><FONT face=Arial size=2>Why is it a problem on the win98se laptop, with   the same program. and several other win98 PC.</FONT></DIV>  <DIV><FONT face=Arial size=2></FONT> </DIV>  <DIV><FONT face=Arial size=2>Help on this matter needed.</FONT></DIV>  <DIV><FONT face=Arial size=2></FONT> </DIV>  <DIV><FONT face=Arial size=2></FONT> </DIV>  <DIV><FONT face=Arial size=2>Best Regards</FONT></DIV>  <DIV><FONT face=Arial size=2></FONT> </DIV>  <DIV><FONT face=Arial size=2>Kjeld Alexander</FONT></DIV>---<BR>You are   currently subscribed to vrf as: carnahal@tycoelectronics.com<BR>To subscribe   send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe   send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages   to this mailing list, email "vrf@it.lists.it.agilent.com". <BR>If you need   help with the mailing list send a message to   "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,  email "vrf@it.lists.it.agilent.com".  <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
