Hi Ralf,
I had the same problem some time ago. You should check your IO configuration
(start menu).
regards,
Friedrich Vllink
Gasunie Research Groningen
-----Oorspronkelijk bericht-----
Van: ralf.eichele@smart-gmbh.de [mailto:ralf.eichele@smart-gmbh.de]
Verzonden: maandag 4 februari 2002 10:06
Aan: VEE Reflector
Onderwerp: vrf VRF: Serious error 979 in runtime application
SMART Electronic Development GmbH - Germany
Von: Ralf Eichele@SMART GMBH am 04.02.2002 10:06
An: VEE Reflector <vrf@lvld.agilent.com>
Kopie:
Thema: VRF: Serious error 979 in runtime application
Hello all,
i've in one of my applications problems with a serious error 979 in the
runtime
version. The error occurs sometimes (e.g. one times per week) when a file
selection box is called. The computer is implemented in a network with many
network drives. It occurs also on other computers in the network, where the
application is installed. Does anybody know, what the cause is and/or have
any
suggestions?
Greetings
Ralf Eichele
(start menu).
regards,
Friedrich Vllink
Aan: VEE Reflector
Kopie:
Hello all,
runtime
any
suggestions?
Greetings
Ralf Eichele
Kopie:
Hello all,
i've in one of my applications problems with a serious error 979 in the runtime
application is installed. Does anybody know, what the cause is and/or have any
suggestions?
Greetings
Ralf Eichele
