<!doctype html public "-//w3c//dtd html 4.0 transitional//en"><html>Hello Phil,<p>I used the mechanism described under PeekPoke and it works fine withWindows95, 98, NT and 2K.
In both the latter cases don't forget to install the driver "ppppdrv"with administrator privileges to be started automatically.<p>I include part of an vrf contribution of 2001.<p>Hope this helps<p>Andre Lehmann
IOM GmbH
<A HREF="http://www.iom-berlin.de">http://www.iom-berlin.de</A><blockquote TYPE=CITE><pre>Hi Chris,Explore these links near the bottom of the "VEE Archives" customer postsalessite:<A HREF="http://ftp.agilent.com/pub/mpusup/pc/binfiles/vee/index.html">http://ftp.agilent.com/pub/mpusup/pc/binfiles/vee/index.html</A> "VEE Win95 PEEKPOKE DLL archive." "VEE WinNT (3.51 & 4.0) PEEKPOKE DLL archive (Parallel Port and I/O Port Driver for NT)." Regarding VEE output to printers:The PCL output files I've examined (with showpcl.exe) always start with lotsof PCL setup commands, which may undermine any previous PCL setup commands auser may have output. Showpcl has many entries on <A HREF="http://www.google.com">http://www.google.com</A>Hope this helps!| Ted Cline| IO Support| Basic, Emerging and Systems Technologies (BEST) PGU| Agilent Technologies| CU-326, 815 14th Street SW, P.O. Box 301, Loveland, CO 80537 USA| 800-452-4844 Customer Support (United States)| 877-894-4414 Customer Support (Canada)| 970-679-5260 FAX| ted_cline@agilent.com| io_support@agilent.com| <A HREF="http://ftp.agilent.com/pub/mpusup/index.html">http://ftp.agilent.com/pub/mpusup/index.html</A> Postsales SupportIO Libraries: <A HREF="http://www.agilent.com/find/iolib">http://www.agilent.com/find/iolib</A> <A HREF="http://www.agilent.com/find/iolibux">http://www.agilent.com/find/iolibux</A>VEE: <A HREF="http://www.agilent.com/find/vee">http://www.agilent.com/find/vee</A>BASIC for Windows: <A HREF="http://www.agilent.com/find/basic">http://www.agilent.com/find/basic</A>Instrument Drivers: <A HREF="http://www.agilent.com/find/inst_drivers">http://www.agilent.com/find/inst_drivers</A> <A HREF="http://www.agilent.com/find/inst_drivers_pnp">http://www.agilent.com/find/inst_drivers_pnp</A>> From: chris_gove@Agilent.com> Sent: Friday, April 20, 2001 12:49 PM> To: vrf@lvld.agilent.com> Subject: vrf VEE parallel port control.> I would like an example of a program (VEE or C)to control a> standard parallel(LPT1) port on a pc, to control individual> control or data lines.</pre></blockquote></html>
IOM GmbH
It sounds as if the registered file type got changed for VEE programs toVXE. Under Win2000 and Vee 5.0,
For VEE programs:
default action: open
Command: "C:Program FilesHewlett-PackardVEE5.0vee.exe" "%1"
For VXE programs:
"C:Program FilesHewlett-PackardVEE 5.0veerun.exe""%1"
Check these settings in your OS.
Mike
At 12:32 PM 6/12/2001 -0500, Lockwood, Mel wrote:
<blockquote type=cite class=cite cite>Something happen to my workenvironment. I try to execute the vee program and it runs like a VXEprogram. Did I change something? Has anyone else run into this? I amworking in 5.0. It was working until I ran the executable program thatlinked other programs. Now it affects all programs. I can get into it byfirst clicking on the vee icon and then open the program.
Any suggestions on this?
Mel Lockwood
Quality Engineering Test Technician
ADC Broadband Infrastructure and access
Tel : 507.665.4785
Fax : 507.665.4786
mel_lockwood@adc.com
This is the "vrf" maillist, managed by Majordomo. To sendmessages to
unsubscriptions are done through the address"vrf-request@lvld.agilent.com".
If you need details, just send a message containing the text"help"
---------------------------------------------------------------------</font></blockquote><x-sigsep><p></x-sigsep><font face="Courier, Courier" size=3>***********************************************************
Michael N. Asbery, NRL Code 5733.20, (202)404-3014, DSN 357
michael.asbery@nrl.navy.mil fax(202)404-7661 :-)
</font></html>
My DUT (Device Under Test) has 3 control pins and I hope to send '0' and '1' signal automatically from notebook to them through parallel port because I don't have enough power supplys.
I am just familiar with instrument command and don't know about port control.
Do you have any idea for this?
Thanks & Regards,
Su-Hyun Kim
Future Communication IC Inc.
The agilent link is for their peekpoke and example file and the jspayne is a
driver (ActiveX) you can download as a sample but need to purchase to use
for a final application. The peekpoke is easier for NT and win2000 and the
jspayne is easier for win95, win98 etc. I have contacted jspayne and the
.ocx file is compatable through winxp, but is a little trickier to use.
www.jspayne.com.
e-mail me if you need more help with them.
MG
From: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]On
Behalf Of Kim,Su-Hyun
Sent: Sunday, February 17, 2002 10:17 PM
To: vee
Subject: vrf parallel port control
control.
Thanks & Regards,
Su-Hyun Kim
Could you send me any example program written with Peekpoke or IO.OCX?
Now I am thinking about purchasing IO.OCX and like to see an example.
Thanks & Regards,
Suhyun Kim
suhyun@fci.co.kr
