Hi Ross,
The problem is that these cards need the 'Configure' objects set up
for each piece of hardware and you cannot put input pins to take the
parmeters. What I have done for these is to have a simple VEE program
called 'Configure0' or the like. All this has in it is the A/D Configure
object which is linked to the card 0. Then I have a more general driver (
I use a 'class'-style methodology ) which I call clAtoD. I make an
'instance' of this called, say, ADC0to3 which tells the class file it has
to load and run 'Configure0.vee', Configure1.vee', 'Configure2.vee' and
'Configure3.vee'. Sounds a bit complex but once it's sets up it is very
easy to add extra boards, change the function of the driver etc.
I can send you some examples if that would help.
Mike Watts
_______________________________________________________________________
Michael J. Watts Consultant PO Box 92
Exeter, Devon
e-mail: MikeJWatts@CompuServe.Com England
tel: +44 7714 339 729 EX4 2YY
Mike Watts
Exeter, Devon
