Hello Reiner,
look for in your component lists (Menu:Device:ActiveX... ) if this component
is checked. VEE tries to load it even if you do not use it!.
Do not forget to look into all of your vee-libraries you load at runtime as
well.
Georg Nied
Software-Development
Hansestr.7 - 51149 Cologne
Germany
Mail: info@gn-software.de
> -----Original Message-----
> From: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]On
> Behalf Of Reiner Schlieker
> Sent: Tuesday, March 20, 2001 11:07 PM
> To: vrf@lvld.agilent.com
> Subject: vrf error
> Hello all,
> I'm using Vee 6 on an NT machine, and I'm getting a warning
> when I load a program that it can't load a certain Active X
> application (HHCtrl 4.0) Nowhere in this program do I use
> any ActiveX controls at all, so I'm perplexed as to why this
> error would occur. The program runs despite the error. Does
> anyone have any insight as to why this might be happening?
> Any feedback would be appreciated.
> Thanks,
> Reiner Schlieker
> Test Equipment Designer
> Siemens Milltronics Process Instruments Inc.
> Phone: (705) 740-7553
> Fax: (705) 740-7692
> e-mail: reiners@milltronics.com
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.agilent.com".
> Subscriptions and
well.
Georg Nied
Germany
> Subject: vrf error
> Hello all,
> Thanks,
> Reiner Schlieker
> Fax: (705) 740-7692
> Subscriptions and
I'm using Vee 6 on an NT machine, and I'm getting a warning when I load a program that it can't load a certain Active X application (HHCtrl 4.0) Nowhere in this program do I use any ActiveX controls at all, so I'm perplexed as to why this error would occur. The program runs despite the error. Does anyone have any insight as to why this might be happening? Any feedback would be appreciated.
Reiner Schlieker
Fax: (705) 740-7692
