vrf AW: VRF arrays
Question asked by VRFuser on May 20, 2003
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2800.1141" name=GENERATOR></HEAD><BODY style="FONT: 10pt Courier New" leftMargin=5 topMargin=5><DIV><SPAN class=394055907-21052003>If you are able to change your program using records of arrays, you can save them as datasets, which will give you a lot of advantages on one hand but the disadvantage of being tied to vee processing your data on the other hand.</SPAN></DIV><DIV><SPAN class=394055907-21052003>Using XML is possible also, but this requires your own library of functions to read, write and interprete XML.</SPAN></DIV><DIV><SPAN class=394055907-21052003></SPAN> </DIV><DIV><SPAN class=394055907-21052003>Hartmut</SPAN></DIV><BLOCKQUOTE>  <DIV class=OutlookMessageHeader dir=ltr align=left><FONT   face=Tahoma>-----Ursprngliche Nachricht-----<BR><B>Von:</B>   tw@huber-online.com [mailto:tw@huber-online.com]<BR><B>Gesendet:</B> Mittwoch,   21. Mai 2003 10:00<BR><B>An:</B> VEE vrf<BR><B>Cc:</B>   vrf@it.lists.it.agilent.com<BR><B>Betreff:</B> [vrf] [VRF]   arrays<BR><BR></FONT></DIV>  <DIV>  <DIV>VRF</DIV>  <DIV> </DIV>  <DIV>Hello,</DIV>  <DIV>when I up to now worked with arrays I did it with a external file and   loaded the datas over 'from file' and 'Get values'.</DIV>  <DIV>Is there another easier possibiliy for working with datas from an array   ?</DIV>  <DIV> </DIV>  <DIV>Best regards</DIV>  <DIV>Thomas Walter</DIV></DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR> </DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR> </DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR> </DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR>To: vrf@agilent.com<BR>Cc:   vrf@it.lists.it.agilent.com<BR></DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR>To: vrf@agilent.com<BR>Cc:   vrf@it.lists.it.agilent.com<BR></DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR>To: vrf@agilent.com<BR>Cc:   vrf@it.lists.it.agilent.com<BR></DIV>---<BR>You are currently subscribed to   vrf as: Hartmut.Gohdes@rfsworld.com<BR>To subscribe send a blank email to   "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to   "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,   email "vrf@it.lists.it.agilent.com". <BR>If you need help with the mailing   list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,  email "vrf@it.lists.it.agilent.com".  <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
