Guy,
On windows try a shortcut with this command line:
"C:Program FilesAgilentVEE Pro RunTime 6.0veerun.exe" -maximize
<progname>
There's also a -geometry option where you specify width, height and
position. Look up command-line options in the VEE help.
I don't know any way of adjusting window size once the program is running,
ie from within VEE. Maybe call a function in the user32.dll?
Hope this helps,
Warren Pickles
From: Guy Bonneville [mailto:guybonne@nortelnetworks.com]
Sent: 14 February 2001 20:05
To: 'vrf@lvld.agilent.com'
Subject: vrf VXE run-size
Does anybody have a routine to adjust the size of run time execution window.
Guy Bonneville
<progname>
Hope this helps,
Warren Pickles
Guy Bonneville
