Thank you, Jase!
Best Regards,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> -----Original Message-----
> From: jason.hicks@nokia.com [mailto:jason.hicks@nokia.com]
> Sent: Wednesday, February 06, 2002 2:06 AM
> To: scott_bayes@agilent.com; m_kozlov@sar.ru
> Cc: vrf@lvld.agilent.com
> Subject: RE: vrf RE: Update on VEE-NR additional defect
> Here is another workaround.
> Before writing to the file put a text array wrapper around
> the record, and write the container to the file. Read the
> container back and then remove the wrapper. This means you
> can still use the Variant variable to store the record.
> BR
> Jase
> From: ext scott_bayes@Agilent.com [mailto:scott_bayes@Agilent.com]
> Sent: 29 January 2002 23:15
> To: m_kozlov@sar.ru
> Subject: vrf RE: Update on VEE-NR additional defect
> Mikhail, we agree that your example demonstrates a defect,
> and it is in our
> database.
> R&D found a couple of workarounds that may help if this
> defect is causing
> you problems:
> 1 - declare the record, not as a type Variant, but as a
> Record with fields A
> and B. See attached example "VRF defect report workaround 1.vee".
> 2 - do not declare the record at all. See attached example "VRF defect
> report workaround 2.vee"
> Sincerely,
> Scott Bayes
> 970 679 3799 Tel
> 970 635 6867 Fax
> > From: Mikhail Kozlov [mailto:m_kozlov@sar.ru]
> > Sent: Friday, January 25, 2002 10:48 AM
> > To: BAYES,SCOTT (A-Loveland,ex1)
> > Subject: Update on VEE-NR additional defect
> > Hi all,
> > Unfortunately I do not find defect database a devect that I
> > submitted to
> > Agilent some time ago.
> > The problem appears when you try to write a record that save
> > in a global
> > variable, which type is variant, to file in container format
> > and then read
> > this file. See attachment file.
> > Thanks
> > Mikhail Kozlov
Best Regards,
Scott Bayes
970 679 3799 Tel
970 635 6867 Fax
> BR
> Jase
> To: m_kozlov@sar.ru
> and it is in our
> database.
> defect is causing
> you problems:
> Sincerely,
> Scott Bayes
> 970 679 3799 Tel
> 970 635 6867 Fax
> > Hi all,
> > submitted to
> > in a global
> > and then read
> > Thanks
> > Mikhail Kozlov
Has somebody problems with the matlab.script server under Windows 2000
SP2 and Vee 6.01 Pro ???
The Matlab.script Server give us approximately 40 "Registry Error"
messages when the user account under Win2000 has no Administrator
rigths.
With Administrator rights is all fine.
Is there a solution ???
Stefan Sordon
SHF Communication Technologies AG
Amalienstrasse 14
12247 Berlin
Zentrale: Tel: ++ 49 (0)30 77 20 51 0
Direkt: Tel: ++ 49 (0)30 77 20 51 11
Fax: ++ 49 (0)30 7 53 10 78
www.shf-communication.de
