vrf More on Time Zone issue
Question asked by VRFuser on Apr 4, 2002
If you are using Office 97, then the help files for ms word and ms excel are
"vbawrd8.hlp" and "vbaxl8.hlp" respectively.
Rahul Bheemidi
Agilent Technologies
From: Wills, Mark [mailto:MWills@tycoelectronics.com]
Sent: Thursday, April 04, 2002 4:09 AM
To: 'Rolf.Neumann@infineon.com'
Cc: vrf@lvld.agilent.com
Subject: RE: vrf Copying sheet values
Many thanks Rolf, this is just what I needed.
I did also ask before whether anybody knew how to get the help to work
correctly when selecting active-X functions from the
Device > Function & Object Browser. All that I seem to get is "There is no
help topic for (selected member etc)"
Are some additional Office help files required to be installed or something
Mark Wills
Principal ATE Engineer
Wireless Automotive System Group
> * E-mail:  mwills@tycoelectronics.com
> * Phone: +44 (0)1908 574209 (direct line)
> * Phone: +44 (0)1908 574200 (switchboard)
> *  Fax:     +44 (0)1908 574300
Tyco Electronics UK Limited  M/A-COM Division
Featherstone Road
Wolverton Mill
Milton Keynes
MK12 5EW
Creating chaos out of order !
From: Rolf.Neumann@infineon.com [mailto:Rolf.Neumann@infineon.com]
Sent: 04 April 2002 11:58
To: Wills, Mark
Subject: AW: vrf Copying sheet values
Hi Mark,
find attached a (very)short example of copying values
in Excel with the PasteSpecial command. Due to lack of time
I've only made an example of copying data within the same
sheet, but maybe this can show you the right way ... .
Hope this is what you've needed
Rolf
Rolf Neumann
Infineon Technologies
WS TI DS 15
Otto-Hahn-Ring 6
81730 Mnchen
Germany
Tel.: +49 89 234-44484
Fax : +49 89 234-718178
Von: Wills, Mark [mailto:MWills@tycoelectronics.com]
Gesendet am: Donnerstag, 4. April 2002 11:46
An: Vee Reflector (E-mail)
Betreff: vrf Copying sheet values
Hi All,
     I posted a this request earlier this last week and had one reply
offering a ready made solution at a fee which I don't want as I have most of
the code completed and am only missing this last bit, so I'll try my luck
again.
Please can anybody help with the correct command syntax to copy only the
values from one sheet to another using PasteSpecial.
Just for info the two sheets are in different workbooks, although I this
shouldn't matters.
Any help would be greatly appreciated.
Mark Wills
