Open a Command Box and enter 'net share /?'. The help text should give you all the information you need.
best regards,
G. Nied
Georg Nied - Software-Development - Hansestr.7 - 51149 Cologne - Germany
Tel: +49 2203 9770915 - Fax: +49 2203 9770924 - eMail:info@gn-software.de
-------- Original Message --------
Subject: [vrf] pc commands (28-Mrz-2003 10:57)
To: vrf@it.lists.it.agilent.com
> Hi
> if you look at a folder which is shared in win 2K it shows the hand ok? I
> need to use the PC command in vee to eanble sharing a folder i create.any
> idea of the command to use
> thanks
> Malcolm Bint
best regards,
G. Nied
> Hi
> thanks
> Malcolm Bint
thanks
Malcolm Bint
