Dear all,
I am developing a cheap GPIB interface board to be used in dedicated
measurement setups providing digital I/O and dedicated additional functions,
e.g. such as stepper drive. ...
I implemented the identification code that can be retrieved using the
command *IDN?. I followed the guidelines found on the Agilent web site, i.e.
to have four fields separated by commas.
Although I can read the identification string using *IDN? and a subsequent
read command in VEE, the VEE instrument manager is not able to read the
proper device name when scanning the bus.
What is wrong?
Hans-Joachim Fischer
ESF GmbH
Brennerweg 7
D-89143 Blaubeuren
+49-7344-919693
+49-7344-919691 (fax)
+49-175-40 74 5 74 (GSM)
http://www.esf-gmbh.de
What is wrong?
ESF GmbH
Brennerweg 7
D-89143 Blaubeuren
+49-7344-919693
> not able to read the proper
> bus.
Odd! Are you asserting EOI with the last byte of the response?
-SHAWN-
