vrf Using "CHAR" format to read from an Instrument
Question asked by VRFuser on Jun 12, 2001
Hi Mel,
     Firstly I assume that you are using the code that I sent. If this is
the case then the second program that executes is executed using veerun.exe,
which means that irrespective of whether or not the file is actually saved
as a development file .vee then it will be run as a runtime file .vxe. From
what you have written, and I may be wrong, you want the second file that is
executed to be in development mode. If this is the case then change the
command
installDir()+"\veerun.exe  -maximize -disallowclose"+a
to
installDir()+"\vee.exe  -maximize -disallowclose"+a
This should work for you I hope that this answers your query.
Mark Wills
Principal ATE Engineer
> * E-mail:  mwills@tycoelectronics.com
> * Phone: +44 (0)1908 574209 (direct line)
> * Phone: +44 (0)1908 574200 (switchboard)
> *  Fax:     +44 (0)1908 574300
Tyco Electronics UK Limited  M/A-COM Division
Featherstone Road
Wolverton Mill
Milton Keynes
MK12 5EW
Creating chaos out of order !
> -----Original Message-----
> From:     Lockwood, Mel [SMTP:Mel_Lockwood@adc.com]
> Sent:     12 June 2001 18:33
> To:     Vrf (E-mail)
> Subject:     vrf program run
> Something happen to my work environment. I try to execute the vee program
> and it runs like a VXE program. Did I change something? Has anyone else
> run into this? I am working in 5.0. It was working until I ran the
> executable program that linked other programs. Now it affects all
> programs. I can get into it by first clicking on the vee icon and then
> open the program.
> Any suggestions on this?
> Mel Lockwood
> Quality Engineering Test Technician
> ADC  Broadband Infrastructure and access
> Tel : 507.665.4785
> Fax : 507.665.4786
> mel_lockwood@adc.com
> This is the "vrf" maillist, managed by Majordomo.  To send messages to
> this maillist, just email to "vrf@lvld.agilent.com".  Subscriptions and
