Von: Andr Lehmann [mailto:a-lehmann@iom-berlin.de]
Gesendet: Freitag, 3. Mai 2002 17:20
An: vrf@lvld.agilent.com
Betreff: Re: vrf using ntpio.exe (PPPPDVR.SYS) under Windows2000 ???
Hello Carsten,
I use PPPPDVR.SYS under Windows 2000, and it works.
After running <DVRLOAD.EXE> (comes with ppppdvr.sys) I did the following
(the
names are "guessed" translations from the German Windows version), while
administrator privileges are necessary:
start "Device Manager"
enable "show hidden devices" under "View"
selected "non-PNP drivers"
selected "properties" from context menu of "ppppdvr"
started the driver, selected "automatically" for "type of start"
(in order to have this driver started for non-administrator users)
Check whether ppppdvr.sys runs:
in the console window "Computer administration" (??)
select "System"
select "System information"
select "Software environment"
select "Drivers"
for "ppppdvr" state=running should be displayed.
After doing all this, I was able to send data over parallel port from VEE. I
did
not try to receive data.
Good luck!
Andre Lehmann
IOM GmbH
> Hello,
> i want to use the "Parallel Port I/O for Windows NT"-Driver called
> PPPPDVR.SYS under Windows 2000.
> But it seems like it is only for Windows NT 3.5/4.0.
> Does anybody experienced this problem and perhaps get a solution?
> Best Regards Carsten Glahe.
Hello Carsten,
(the
select "System"
select "Drivers"
did
Good luck!
Andre Lehmann
IOM GmbH
> Hello,
