vrf VRF compare 2 source codes
Question asked by omer.akbas on May 22, 2003
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2600.0" name=GENERATOR></HEAD><BODY style="FONT: 10pt Courier New" leftMargin=5 topMargin=5><DIV><SPAN class=621473906-23052003>If you have a UNIX machine around you you can use the "diff" command to find out differences between two text files:</SPAN></DIV><DIV><SPAN class=621473906-23052003>diff file1 file2</SPAN></DIV><DIV><SPAN class=621473906-23052003>LINUX might have a similar command but I am not sure.</SPAN></DIV><DIV><SPAN class=621473906-23052003>If you don't have an access to a UNIX machine, I can help you out if you send me the files</SPAN></DIV><DIV><SPAN class=621473906-23052003>Omer Akbas</SPAN></DIV><DIV><SPAN class=621473906-23052003>Istanbul, Turkey</SPAN></DIV><BLOCKQUOTE>  <DIV class=OutlookMessageHeader dir=ltr align=left><FONT   face=Tahoma>-----Original Message-----<BR><B>From:</B> tw@huber-online.com   [mailto:tw@huber-online.com]<BR><B>Sent:</B> Friday, May 23, 2003 9:36   AM<BR><B>To:</B> VEE vrf<BR><B>Cc:</B>   vrf@it.lists.it.agilent.com<BR><B>Subject:</B> [vrf] [VRF] compare 2 source   codes<BR><BR></FONT></DIV>  <DIV>  <DIV>VRF</DIV>  <DIV> </DIV>  <DIV>Hello,</DIV>  <DIV>when I have 2 different source codes and<EM> I am interessted to   know the differnt between the both, is there a trick to find that out   ??</EM></DIV>  <DIV><EM></EM> </DIV>  <DIV>Best regards</DIV>  <DIV>Thomas Walter</DIV></DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR> </DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR> </DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR> </DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR> </DIV>  <DIV style="FONT: 10pt Courier New"><BR><BR>To: vrf@agilent.com<BR>Cc:   vrf@it.lists.it.agilent.com<BR></DIV>---<BR>You are currently subscribed to   vrf as: omer.akbas@arcelik.com<BR>To subscribe send a blank email to   "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to   "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,   email "vrf@it.lists.it.agilent.com". <BR>If you need help with the mailing   list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>_____________________________________________________________________________________________________________________________________________<div><font color="gray" size="1">Bu e-posta mesaji kisiye ozel olup, gizli bilgiler iceriyor olabilir. Eger bu e-posta mesaji size yanlislikla ulasmissa,  icerigini hic bir sekilde kullanmayiniz ve ekli dosyalari acmayiniz. Bu durumda lutfen e-posta mesajini kullaniciya hemen geri gonderiniz  ve  tum kopyalarini mesaj kutunuzdan siliniz. Bu e-posta mesaji, hic bir sekilde, herhangi bir amac icin cogaltilamaz, yayinlanamaz ve para karsiligi satilamaz.  Bu e-posta mesaji viruslere karsi anti-virus sistemleri tarafindan taranmistir. Ancak yollayici, bu e-posta mesajinin - virus koruma sistemleri ile kontrol ediliyor olsa bile - virus icermedigini garanti etmez ve meydana gelebilecek zararlardan dogacak hicbir sorumlulugu kabul etmez.
This message is intended solely for the use of the individual or entity to whom it is addressed , and may contain confidential  information. If you are not the intended recipient of this message or you receive this mail in error, you should refrain from making any use of the contents and from opening any attachment. In that case, please notify the sender immediately and return the message to the sender, then, delete and destroy all copies. This e-mail message, could not be copied, published or sold for any reason. This e-mail message has been swept by anti-virus systems for the presence of computer viruses. In doing so, however,  sender  cannot warrant that virus or other forms of data corruption may not be present and do not take any responsibility in any occurrence.</font></div>_____________________________________________________________________________________________________________________________________________</BODY></HTML>
