This is quite simple, as I do it in my programs.
I define serial interfaces always only for COM1.
In the program I use the control input Address to define wheter actually it
is COM1 or COM2. I read this information from a global variable.
This global variable is set during program initialization by information
read from a hardware init file, which is a simple ASCII file.
I hope this helps.
Kind regards
Hans-Joachim
Please note:
The domain www.esf-sys.de <http://www.esf-sys.de> will be closed soon. This
was just an interim domain, as our original domain www.esf-gmbh.de
<http://www.esf-gmbh.de> was stolen by a service provider. Now we have
again access to www.esf-gmbh.de <http://www.esf-gmbh.de> and will switch
from www.esf-sys.de <http://www.esf-sys.de> to www.esf-gmbh.de
<http://www.esf-gmbh.de> within reasonable time without further
announcement.
You can already now use esf-gmbh instead of esf-sys in all e-mail addresses.
Our domain www.fischer-tech.de <http://www.fischer-tech.de> will remain
valid including all related e-mail addresses.
Elektrische Signalverarbeitung Dr. Fischer GmbH
Dr. Hans-Joachim Fischer
Geschaftsfuhrer
Brennerweg 7
89143 Blaubeuren
+49-7344-91969-3
+49-7344-91969-1 (Fax)
+49-175-40 74 5 74 (mobil)
http://www.fischer-tech.de <http://www.fischer-tech.de>
http://www.esf-gmbh.de <http://www.esf-gmbh.de>
http://www.rttt-dsrc.de <http://www.rttt-dsrc.de>
This e-mail, and files transmitted with it, are for the sole use of the
recipient(s) and should not be forwarded without permission. Personal
messages do not necessarily represent the views of Elektrische
Signalverarbeitung Dr. Fischer GmbH.
You may not copy this information or use it or disclose it to anyone else.
If you have received this message in error, please notify the sender and
delete it from your system immediately.
Elektrische Signalverarbeitung Dr. Fischer does not accept liability for
errors, viruses or omissions in the content of this message.
> -----Ursprungliche Nachricht-----
> Von: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]Im
> Auftrag von ASHLEYDER@aol.com
> Gesendet: Mittwoch, 10. April 2002 10:12
> An: vrf@lvld.agilent.com
> Betreff: vrf Changing Com Port
> Hello,
> Anyone know how to globaly change over from Com1 to Com2 within a Vee
> program? I usually write everthing to use Com1 (as many Laptops
> don't have
> Com2 socket or need port replicator/docking station to access).
> But sometimes
> customer wants to use Com2. Any ideas how to do thins simply?
> regards,
> Ashley Derrick
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
I hope this helps.
Kind regards
Hans-Joachim
Please note:
announcement.
Geschaftsfuhrer
Brennerweg 7
89143 Blaubeuren
+49-7344-91969-3
> Hello,
> don't have
> But sometimes
> regards,
> Ashley Derrick
