So, in that field, my records will =
have 50 values instead of the 150 values with which the dataset was =
initially designed.
If you poke around a dataset you'll note that there is exactly ONE
record defnition. Hence all records in the dataset must be identical.
You'll need to put in dummy data or whatnot
Stan
initially designed.
Stan
BTW, has anyone tried the Vxl add-in mentioned by Greg Wale from PassTechnologies? This sounds like it would save me the time (and headaches, judging by the percentage of vrf traffic dedicated to this) to learn how to do this myself.
Reiner Schlieker
Test Equipment Designer
Siemens Milltronics Process Instruments Inc.
Phone: (705) 740-7553
Fax: (705) 740-7692
e-mail: reiners@milltronics.com
>>> "Alejandro Islas" <aislas@kbtel.com> 04/11/02 12:44PM >>>
Hi all, I designed a dataset to which my VEE program stores all the data it measures so that it can be analize later. Until now I have moreless 200 records stored. The problem is that I have been asked to change the number of measurements on a test. So, in that field, my records will have 50 values instead of the 150 values with which the dataset was initially designed. Of course, when I try to store this new record on the dataset an array size error appears. Any idea to be able to store such new record without modifying the dataset??? Maybe there's a way: to fill the array with nulls values but I wonder if that could cause me problems later while trying to plot those results on matlab??? Like always, thanks in advance guys!!
Alejandro Islas
Kb/TEL
Mexico
