Words to live by.
On the odd time that a program becomes corrupted and won't open, I open the
".bak" file in notepad or wordpad and save it as a ".vee" file. This has
worked many times and saved me the frustration of having to redo the older
version.
From: Bill_Karnavas@transarc.com [mailto:Bill_Karnavas@transarc.com]
Sent: Friday, April 12, 2002 7:37 AM
To: vrf@lvld.agilent.com
Subject: Re: vrf VEE 6.01 Fatal Error
Just a couple comments on safe coding.
I've been working with VEE for a few years now and it is not perfect,
and will occasional eat a file.
There are a couple practices that you can do to minimize the impact of
these problems and generally improve your coding style.
1) Most important and already mentioned here, is to not keep saving to
the same file. I tack a number on the end of my root file name and
increment it as I go. I rarely work more than half an hour before
saving to a new numbered file.
2) Going along with version numbers, I keep a notepad going in each
file which comments on what I have been working on and is new or
changed in each version. If a version becomes corrupted, by vee or
disk, I can often look at the comments (using a text editor) and
recall most of what was lost in that revision.
3) Keep code files reasonably sized. This was probably a factor in
the original post on this, in my opinion, where the file was around
2MB. It is just good programming style to break large projects up
into smaller groups of related functions, usually refered to as
modules. There are lots of good programming reasons to do this, like
making code reuse more practical and testing possible. In many of my
own projects I find that there is a test as a whole that is run, but
many times there is a need to run some part of an analysis outside of
the whole and then taking that module and giving it a new front end
makes for some real quick development of a new program that makes me
look good. I try to keep modules down to 200-300K. Working on
modules much bigger seems to bog down and the risk in code loss due to
corrupt file goes up a lot.
lBill
version.
lBill
A week ago or so, there was some
discussion on this subject and some sample VEE
files.
Could someone please send me the sample VEE
file that did this conversion. We have a similar problem
trying to convert negative real numbers to IEEE format.
Thank you in advance
Rob
Rob Marquardt
System Test Engineering
Rockwell Automation / Allen-Bradley
1201 So. 2nd Street
Milwaukee, Wisconsin, 53204-2496, USA
414-382-3098 Phone
414-382-4820 FAX
RAMarquardt@ra.Rockwell.com
