Hi Pat,
Do you mean direct IO? This is the temporary solution I have implemented.
I would like to know why this 'plug & play' driver doesn't play!
Regards
David Watling
"Pat Vittorini"
<pvitt@sympatico. To: <Dave.Watling@Zarlink.Com>
ca> cc:
Subject: RE: [vrf] Tektronix CSA8000
27-May-2003 02:19
PM
Try sending a text string?
From: Dave.Watling@Zarlink.Com [mailto:Dave.Watling@Zarlink.Com]
Sent: Tuesday, May 27, 2003 4:34 AM
To: VEE vrf
Subject: [vrf] Tektronix CSA8000
Has anyone tried to drive a Tektronix CSA8000, using the Tek plug&play
driver? I am using Vee6.01, and I cannot set up the horizontal and
vertical scales, as the driver appears not to accept the Vee real64
numbers. Thoughts please....
Regards
David Watling
You are currently subscribed to vrf as: pvitt@sympatico.ca
To send messages to this mailing list, email
"vrf@it.lists.it.agilent.com".
Regards
David Watling
