Hi All
Can anyone tell me how to find non 488.2/SCPI instruments on the bus using
the dynamic i/o utility provided in the examples. Instruments such as
HP6622A & HP8562E will only respond to ID?. Is there possibly an upgrade of
firm/software that can be installed to get us over the problems?
Many thanks in advance.
Chris Phipps
Chris Phipps
to write a new record to each dataset in turn, then start again with the
first dataset.
In order to do this, I am using a "For" loop and a "Formula" to create the
dataset names. These names are input to my "To Dataset" object on a "File
Name" pin.
I have set the option "Clear File At Pre-Run" on the "To Dataset" object.
Unfortunately, VEE's behaviour seems to be indeterminate:-
The resultant datasets generally have a new "schema" (the header information
with details of the record type) written each time that a new record is
written.
Sometimes, the dataset only has the last record present (ie the dataset has
been overwritten from the beginning each time it has been accessed).
I assume this behaviour is due to my constantly changing the file name
present at the "File Name" pin. Unfortunately, this is the only way I can
achieve what I want to do.
Has anyone encountered this problem and/or have any suggestions?
I am using VEE Pro v6.00.
TIA & Regards
Paul C
