No attachment
Greeting, Axel
Von: OSSMANN,BILL (A-hsgAndover,ex1) [mailto:bill_ossmann@hsgmed.com]
Gesendet am: Mittwoch, 27. Juni 2001 16:38
An: vrf@lvld.agilent.com
Betreff: RE: vrf Detecting rising edges of a High/Low-Signal
Axel,
Instead of signOf(A-mean(A)) use clipLower(signOf(A-mean(A)),0). This will
clip the -1 results from the signOf function to 0, eliminating the spikes.
Please see the attached program. I have moved some of the calculation from
the second formula box to the first to make it more readable.
Bill Ossmann
bill_ossmann@agilent.com
Agilent Technologies
Imaging Systems Division
>-----Original Message-----
>From: a.kieser@francotyp.com [mailto:a.kieser@francotyp.com]
>Sent: Wednesday, June 27, 2001 9:07 AM
>To: vrf@lvld.agilent.com
>Cc: bill_ossmann@hsgmed.com
>Subject: AW: vrf Detecting rising edges of a High/Low-Signal
>New Problem:
>If I want to detect the zeroes of a sine-wave, I have a
>difficulties, if one
>value of my measurement is exactly zero, there I will get peaks in my
>delta_t=f(t)-graph (see attached example).
>Any ideas?
>MfG
>Axel Kieser
>______________________
>TEM - Raum 311a - Tel. 637
>Gesendet am: Freitag, 22. Juni 2001 16:15
>If you have a non-zero mean, simply subtract the mean (or
>whatever threshold
>you need) from the original data before feeding it to the edge
>detector. You
>could even include the subtraction in the first formula in the
>arguments of
>the signof() functions.
>I got nearly a factor of 30 in speed, from about 4.3 seconds
>down to about
>0.15 seconds.
>Regards,
>Bill Ossmann
>>Sent: Friday, June 22, 2001 10:03 AM
>>Thank you, it's great (3 times faster);
>>my Problem is now, what I have to do if the DC-Part (mean)
>>isn't zero resp.
>>low and high level both are greater than zero? My example with
>>the function
>>generator was not universal enough, I think...
>>Thanks in advance,
>>Axel Kieser
>>___________________________
>>Francotyp-Postalia AG & Co.
>>TEM - Mechanical Development Department
>>Triftweg 21-26
>>16547 Birkenwerder
>>Germany
>>Tel.: +49 (0) 33 03/5 25 - 6 37
>>Fax: +49 (0) 33 03/5 37 07 - 6 37
>>http://www.francotyp.com/
>>Gesendet am: Freitag, 22. Juni 2001 15:31
>>Try the attached which uses array math and a comparator.
>>Bill Ossmann
>>>Sent: Friday, June 22, 2001 5:11 AM
>>>Subject: vrf Detecting rising edges of a High/Low-Signal
>>>Hi,
>>>I have an array which is containing the values of a
>>>measurement of a high /
>>>low-signal, e.g. U(t). I want to analyze this array to get a
>>>function T(t)
>>>where T is the difference between two consecutive rising edges.
>>>Is there a faster method to get them than a 'for...count' and
>>>an 'if' (see
>>>example)?
>>>Thanks in advance,
>>>With best regards,
>>>Axel Kieser
>>> <<Test1.vee>>
>>>Triftweg 21-26
>>>16547 Birkenwerder
>>>Germany
>>>This email message has been swept by MIMEsweeper for the presence of
>>>computer viruses.
>>computer viruses.
>>This is the "vrf" maillist, managed by Majordomo. To send messages to
>>this maillist, just email to "vrf@lvld.agilent.com".
>Subscriptions and
>>unsubscriptions are done through the address
>>"vrf-request@lvld.agilent.com".
>>If you need details, just send a message containing the text "help"
>>to "vrf-request@lvld.agilent.com".
>this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
>computer viruses.
computer viruses.
Greeting, Axel
Axel,
Bill Ossmann
>New Problem:
>Any ideas?
>MfG
>Axel Kieser
>whatever threshold
>detector. You
>arguments of
>down to about
>0.15 seconds.
>Regards,
>Bill Ossmann
>>isn't zero resp.
>>the function
>>Thanks in advance,
>>Axel Kieser
>>Triftweg 21-26
>>16547 Birkenwerder
>>Germany
>>Bill Ossmann
>>>Hi,
>>>function T(t)
>>>an 'if' (see
>>>example)?
>>>Thanks in advance,
>>>With best regards,
>>>Axel Kieser
>>> <<Test1.vee>>
>>>Triftweg 21-26
>>>16547 Birkenwerder
>>>Germany
>>>computer viruses.
>>computer viruses.
>Subscriptions and
>computer viruses.
computer viruses.
my Problem is now, what I have to do if the DC-Part (mean) isn't zero resp.
low and high level both are greater than zero? My example with the function
Thanks in advance,
Axel Kieser
Triftweg 21-26
16547 Birkenwerder
Germany
Bill Ossmann
>Hi,
>function T(t)
>an 'if' (see
>example)?
>Thanks in advance,
>With best regards,
>Axel Kieser
> <<Test1.vee>>
>Triftweg 21-26
>16547 Birkenwerder
>Germany
>computer viruses.
computer viruses.
