Carlos
It is not possible to run 'C' code inside VEE, however VEE can call an
external DLL which has been written in 'C'. The DLL must first be imported
using the "Import Library" object and thereafter it operates in a similar
way to other imported functions.
If you are writing the DLL in Microsoft Visual C++, you will find an
explanation of what to do in the "HPVEE Advanced Programming Techniques"
book.
Borland C++ works also.
Paul Carnell
> -----Original Message-----
> From: owner-vrf@lvld.agilent.com On Behalf Of Carlos Jimnez
> <cjimenez@ivic.ve>
> Sent: Tuesday, June 19, 2001 3:15 PM
> To: vrf@lvld.agilent.com
> Subject: vrf C code and VEE
> If posible to RUN C code inside VEE?
> How I build OCX o DLL for RUN in VEE?
> Carlos Jimnez
> Tel: W: +58 212 504.1576; 1582; 1833
> H: +58 212 322.7413; 321.1382
> e-mail: cjimenez@ivic.ve -> Lab
> cjimenez41165@hotmail.com -> University
> cjimenezcantv@cantv.net -> Home
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and
book.
Paul Carnell
> <cjimenez@ivic.ve>
> Carlos Jimnez
Carlos Jimnez
