> You could store your variables in a dataset; then even if Vee bails with a BRB, you still have all the info available.
While you are at it, given that you have so many globals,
you might consider replacing them with a single global
record. i.e instead of having
globalA
globalB
globalC
you'd have just
global
and the individual variables would then be
global.A
global.B
global.C
Just about as easy to use, and has two big advantages:
(1) you can save the entire set of globals at one time
(2) you can programmatically find out what globals are
defined- since they are just fields of a record
rather than individual variables
Downside is of course the one big packet so it is certainly
less flexible.
just a thought.
Stan
globalA
globalB
globalC
you'd have just
global
global.A
global.B
global.C
less flexible.
just a thought.
Stan
<font size=2 face="sans-serif">Hi all. I have a program with 130 globals. I would like to write them to a file when I get an error. Does anyone have a novel way of doing this without a I/O transition box that has 130 inputs?</font>
<font size=2 face="sans-serif">Regards,</font>
<font size=2 face="sans-serif">Mark
Mark R. Sutliff
GMTO/Applied Measurement Technology
Eastman Kodak Co.
7/23/KP, MC 24392
work # 585-477-4359
pgr. # 585-975-3703
fax. # 585-722-5490</font>---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@it.lists.it.agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
