> For example, if I run a 1Khz sine wave into the input (0-10V P-P), I would
> expect that I could read back enough data to display that sine wave on the
> strip chart object in VEE. All I seam to get are a few data points and
> when I try to increase the number of data points to pull back, I get
error.
Are you using the VEE "Classic" driver or the Plug&Play driver?
(Either one is OK, I can just be more specific with my answer if I know
which one you are using.)
I wrote both of those drivers, so I can help you with the details.
Or you could use direct I/O.
In any case, you need to set the timer and the trigger count. If you leave
the timer at the default 50 nSeconds, you'll need a lot of samples to see
1KHz.
Have you tried the "Soft Front Panel"? Use it to get familiar with the
digitizer.
Les Hammer
Vice President
Complete Test
PO Box 6
Loveland, CO 80539
Les.Hammer@CompleteTest.com
www.completetest.com
error.
1KHz.
digitizer.
Les Hammer
Vice President
Complete Test
PO Box 6
Loveland, CO 80539
digitizer in my VXI test stand. I'm looking for examples of how to use
this card. I guess I'm looking for a digitizer 101 class. I can get it to
take some measurements, but I'm not seeing the results that I expect.
when I try to increase the number of data points to pull back, I get error.
Any examples out there?
Tom Mitchell
