Hi. I'm trying to create a run-time version of my VEE program, one which
includes two bitmap files (small images) that I had to create myself. When
I create the runtime version, though, the executable runs fine but doesn't
display those bitmap icons.
Is there a way to make VEE recognize those icons? They already are in the
same directory as each other.
Amir
Amir
If the output to be returned is over 4K, it fails. I know where the problem
is and will have it fixed shortly.
-SHAWN-
